Washing her bottom
Shayne
Guru
Tired of getting wet trying to get the pressure washer under her I’m sad to learn Clarke are about the only manufacturer not to offer some sort of u bend gutter extension . Plenty of quick release options if I’m lucky enough to buy an adapter that actually fits but then I thought why not just put an elbow in what I got sooo
would this fit ?
I bought a proper L shaped lance for my Kranzle pressure washer, adjustable jet which goes exceptionally wide pattern so you can put plenty of water on without silly pressures likely to cause damage.
However that handy little elbow looks like it will do the trick just as well.
Won't be washing underneath yet, there's still stacks of salt lying on the roadsides, it'll take days of solid rain to shift it, i reckon around mid May before we can clean underneath and start re-applying whatever proofings we use.
