Hi,hi all
i have got water dripping from under the passenger side dash any one got any clues why
cheers snap
noHi,
Has the windscreen been changed?
hi all
cheers snap
The fresh air intake grill Nr the wiper arms, there is a drain in the bottom, could it be blocked.
You beat me to it, that was going to be my next suggetion.Is it coming out of the heater, ie is it running down the passenger side transmission tunnel? Is it water or coolant?
no it seems to be coming down the pillow it is waterIs it coming out of the heater, ie is it running down the passenger side transmission tunnel? Is it water or coolant?
Do you mean the 'A' pillar, if so it could be the drain from the sun roof gutter (if you have sunroof) blocked, or leaking.no it seems to be coming down the pillow it is water
Well doneall fixed water was coming from bolt thread that hold the roof rack down
