i put the temp sensor inside one of these connectors:-
after crimping it, and wrapping loads of electrical tape around the connector and wire, i undid one of the bolts that bolt the rocker cover down onto the head, and then put the bolt throught the connector/temp probe, and did the bolt back up.
the advantage of doing it this way it that even if you burst a rad pipe/put a hole in your rad and loose all your coolant, you will see the engine getting hot instantly!
if you loose all your coolant with the standard temp sensor and gauge, you wont know about it as the gauge wont go up!
on mine, i like to keep it between 65-80 degrees. anything above 85 and my original gauge starts climbing rapidly, but below this the original gauge wont move above halfway.
with the temp gauge/controller you can set it to switch a relay controlling an electric fan on and off at different temps.
so you could set it to switch the fan on if the engine gets to say 80 degrees, and then switch the fan off at say 70. you could also link up a buzzer/alarm.
i tend to keep an eye on my gauge, which is what i do with all the gauges. id say every 30-60 seconds i have a quick glance at all the gauges, i dont even think about it anymore, its just habbit.
