Wet drivers footwell when it rains!! Help pls.
Ecky Thump said:
Steve
Best bet is an electric heater overnight if you are able (a window or two slightly cracked open to allow moisture laden air out) then see if your carpet gets wet again.
A bag of silica left for a couple days and nights will also suck it all up. Once done, leave in low oven with open door to dry them out again.
http://cgi.ebay.co.uk/DESSICANT-SILICA- ... 500wt_1156
Good point forgot about possible condension, I ll take that into account, one on each pillar, it's pressed between the lining and pillar, so if it gets soaking wet as opposed to being moist and compare with the other side tissue to give some sort of indication to any leak but hopefully has been resolved anyway. Thanks for the mention.
Dont know if this has been mentioned before, but I sorted mine by cleaning the drain slot under the sill with the end of a small cable tie. The water comes from the sunroof drain and empties into the sill. The slot is not very big and was clogged up with dirt, checking it is now part of the maintainance schedule.
