I'll will be fitting OME851 springs up front over Easter along with my EFS shocks and steering damper (I was given all the springs when I bought the truck, lucky me!!). *The springs are labelled A and B. The B one seems to be slightly taller than than the A spring which goes against the info I have which is to fit the B to the passenger side.*
Surely the taller spring needs to go where there is constant weight - i.e. the driver? *Or am I missing something??
Or is it a case if fit it all and check measurements then swap them around till it's all level??
TIA
TIA
