BobMurphy
- Mar 1, 2010
I have a couple of Transfer Boxes on the bench with the intention of building one good one out of the pair for the owner, Ali (ILLYSINSTA on the other site ).
The box that came out of his truck is very corroded on the outside. In fact the bash plate that protects the lower casting is rotted away and fell apart when I finally got the bolts out.
By contrast, the inside is the cleanest I have seen and I haven't found any wear - due to age & use - anywhere.
The Centre Differential was in the locked (HL) position, and I couldn't move the sliding pinion that locks it . . . Not looking good.
So I took the end cover off the Diff . . . . .
Now, a Planet Carrier (the bit inside the drum) should look like this:
But when I took the end cover off, this is what fell out :
This is what happens when the truck is run on dry roads with the Centre Diff locked (though I have never seen one so completely destroyed before ).
Despite this damage, the insides were beautifully clean:
So, the moral of this little tale is - Don't lock the Centre Diff on a dry road for more than a few seconds .
Bob.
Bob.
