Hi all, which battery will you recommend for a a 1994 diesel 4.2l 80 series? Need to replace both.
Context: Car not starting after being switched off for a period of time,eg. overnight. (Seems like the batteries charge when driving - had the alternator and starter checked out, but apparently no problems there). But they then inexplicably lose charge over a few hours. Sometimes even shorter periods. Would you say that is a dead battery in need of replacement? Known cruiser/battery behaviour?
There is a kink to this though.. I am in Malawi on an overland trip in the middle of nowhere and the choice of batteries are limited to say the least.
Is it in any way possible or advisable to fit leisure batteries? Been recommended and assured two 12v Willard leisure/marine batteries will do the trick.. but I dont know much, and this seems like bad advice. Am I right? What are the ups and downs if at all possible?
Many thanks!
Many thanks!
