Well, there's a few things.
1. It's the only fridge freezer that will fit in the space I have in the trailer and that makes me cross.
2. The literature lies. Well, it's unclear about the truth.
- the lid can be adjusted to open both ways. Not really. There are four edges - it can only open on 2
- the temperature of the fridge and freezer CANNOT be set independently but sort of suggests it can
3. The light inside is useless
4. the shape inside is stupid.
- Because it's deep, you need to use baskets. This means you can't stand bottles up inside
- Any bottles can only be as tall as the basket is long; which is shorter than a wine bottle
5. The freezer bleeds through the lid and you have to chip ice off all the time. Ahh, that's because you have the fridge set too low and that makes the freezer -10 C less. OK so if I set the fridge at chilled which is 4 C the freezer will be at -6? Yes. F*** off. It's not. I have experimented extensively and set the freezer to the point at which water actually freezes - which is different in the middle, bottom and edges of the compartment. This usually means setting the fridge at zero which is then too cold for chilled items.
6. The first one I had failed in Germany and it took me weeks to get it replaced even though it was less than a year old.
7. It doesn't have a drain and the ice melts into the fridge and makes everything wet.
8. I hate it.
9. The baskets are stupid money, but I've had to order another small one to stack in the fridge instead of the large top basket so I can stand bottles up - which loses me space.
10. I hate it
