Who is up for a rear shelf for a 120 series?
Graham
Here I have no use for my rear parcel shelf.
It is made from shaped contoured 19mm or 15mm (can't remember) plywood.
Under the wood, it has a 25mm box steel frame, with a left and right fastening that clips into the retainer that normally retains the 3rd row seats.
It is covered with beige carpet at the moment.
It fits in a treat.
Simply remove the 3rd row seats, then with the seat clips still in the open position, position this parcel shelf in place, and push down on each side.
the seat retaining clips will snap closed, an firmly holding the shelf in place.
The shelf does easily hold 100kg, as I have sat on it many times, when doing things in the back of my Land Cruiser.
£40.
Collect, or sort your own courier out, at your expense
I will print out the courier sticker labels, and could wrap it in some cardboard.
Gra.
I will post up images tomorrow.
Gra.
Here,
You can see where the inverter was fastened down, as it has compressed the carpet pile.
I quick brush with a stiff brush would bring it back up.
But I would just pull the carpet off, it is just glued on, and for £5.00 from B&Q get some grey car carpet, and glue that on.
Gra.
