Bert
- Feb 11, 2016
You might get some fouling - it depends.
Sorry, I know that doesn't answer your question but I have fitted 265/75R16s on both the original Collie alloys and more recently on 80 series alloys. They both fouled a tiny bit on LH full lock, only on the mudflap, before and after I had a 50mm suspension lift. Others have fitted the same size without any issues.
However on most accounts I've read (and I've read very many ) - 265/75 is a size that you can "upgrade" to without any significant issues.
Ok. So as long as I don't go full lock, they SHOULD be ok for now?
Next question, I don't really want to put a 2" lift on her, so Chadr, where did you source the parts for the 50mm lift, and was it a straight case of putting in new shocks etc without mucking about with anything else, pipes, wiring, fuel tank etc.?
I need to keep it simple as I'm quite simple
