Hi Guys,
We've taken the winch switch to a new level.
Engineering and over-engineering seems to be our forte.
We've installed a 3-way marine switch.
It works by wiring the main battery and leisure battery into the marine switch as well as the winch.
The marine switch has a big dail on it with 4 positions.
Position 1 = main battery
Position 2 = leisure battery
Position 3 = both (1+2 in paralel)
Position 4 = Off
This enable you to choose what you want to use with the winch.
If the engine is running use Pos 1
If the engine is off use Pos 2
If you are really in the SH*T use 3
If your not using it it remains on Pos 4
If anyone wants a picture please drop me a line.
Hope this helps
Andre
This is solely for the winch
