Paul80-100
- Jan 24, 2023
As title suggestes 100 series 2002 getting bubbling in pas tank and heavy steering but not all the time . Some times steering normal then further around go with lock gets easier and harder as if preasure issue.
The vehicle is new to myself and I believe this could be a existing issue as I can see the pas pump has been of at some point as not been fitted with correct sealing washer and just rtv sealant to block. Also appears to have a new steering rack installed very recently.
From what I can figure it would appear air is in system to give the bubbles but where it's getting in is anyone's guess as cant seem to see no visible leaks even though was previously little wet around area presuming from pas coming out the tank itself.
Could it be the pump or any known common issues applying more revs does not make steering easier.
I happen to come upon a valve that some talk about preasure relief valve . Are these commen and would a failed one give these symptoms.
Bit reluctant to just go straight to the pump as am guessing that's what was checked before replacing rack so just crossing other possible causes first
180k on car 1hdt-fte
Thanks
Thanks
