As I said, ‘if a breather has become detached’ … @Chas has had first hand experience of this on his 80. Could be worth following the breather back down and checking it is firmly connected.No Dipstick Starcruiser . The breathers are up above the bell housing between the block and firewall, the water would have to be pretty deep to get in there
How deep deep was the water butwat?
I’ve had similar before on others. I feel your pain…usually when the hand that holds the hose comes to an abrupt stop against something solid that you once thought to be out the way.Good point didnt see that. I wish mine had become detached when I was trying to extend the breathers , I tore the hose before it let go of its home
