guruvetim
- Oct 7, 2017
Should the EDIC on a 2H stay in the over inject position for a few seconds while the engine is starting?
Mine flicks into the over inject position when you turn the ignition on but the immediately moves to the run position before the key is turned to start.
The engine does start although it often dies after the first attempt but will usually be fine on the second or third attempt.
It stops as it should if you earth the oil pressure switch wire.
