- Jun 30, 2011
I've only managed to make mine not start on 2 occasions, and both times intentionally sort of.. to my mind they are the only 2 ways it won't start if the engine runs fine up to that point.. immobiliser (I tried a cut key without the chip- turns over but no fire) or fuel (after a new diesel filter before priming just for the hell of it)
I've been thinking about it for the last few hours and coming up with nothing else that could explain it. My though process based on whats needed to make a diesel engine work is below -
Start stream of consciousness...
Air- unaffected by temperature bar being less efficient
Battery - couldn't be affected by engine block temperature
Starter motor - likewise.. if it starts cold, surely it can turn it warm
Diesel delivery - why only when hot?
Diesel pump - leaking back is common on old inline mechanical pumps I work on with tractors, but with the pressure from a common rail system I'm not as sure about how it happens. Electronic SCVs can be problematic after plenty of miles, but haven't seen them prevent starting, more developing a 'flat spot' in the rev range.
Injectors: thermal expansion causing an issue? I'm not a metallurgist or a diesel wizard so it may be possible, but I'd have my doubts
I would like a cheese sandwich...
Immobiliser- how does engine temperature possibly affect this...
Cooling system - is there a cooling problem with the rad that's making it run hot, and do Toyota have a hidden sensor that won't allow it to start if water temps are above a certain temp? There's not that many sensors on the KD unit... so I don't think so but maybe someone else knows
Now, where's that cheese?
...end stream...
...end stream...
