Hi guys
Just got a early 2002 4.7 VX, which also has a decent LPG conversion.
Gutted as when collecting I noted that it had a bit of a lumpy idle, which completely dissappears when driving. I assumed it was probably the spark plugs as I know LPG burns hotter than petrol and so they get through spark plugs quicker.
Put it in to a local garage and they have advised that the plugs are almost brand new, and they suspected burnt engine valves. They diagnosed this by listening to the 'pop' of the idle through the exhaust, and general experience, and recommended a compression test.
They did a compression test, and all valves were in the 13.5 - 14 range, except one in one bank running 7.5, and one in another bank running 8.
They are inlet and exhaust (different sides/ends).
The labour to strip and replace is 19.9 hours per bank - which is 40 hours labour!!! Gutted!
Has anyone come across this or a similar issues? Will it definitely be down to burnt valves?
Are burnt valves different to stuck valves?
Is there an easy fix???
Help needed! Worried!!!
Thank you
Thank you
