VirginiaColorado
- Jan 10, 2024
Hello!
Recently came into ownership of a 1997 Land Cruiser Colorado with 3.0 TD engine (1KZ-TE, model 95?). My goal is to get it running, and it was running until recently. I've never taken on a project like this, and although I am handy and can fix things, I'm just not sure where to start on a vehicle. So, here goes...
Currently, I'm having problems getting it to start. When cycling through the ignition steps, lock, off, acc, start, it's good until you go to start, then all lights go out and nothing. It's like the whole electric system shuts down. This has happened before and when I put the battery charger on each out to check, they are at 100% -- sometimes this "resets" the system and I am able to start it, but not recently. Just goes into shut down mode. Battery is draining at the rate of about 10-20% per week if it just sits. There are no accessories plugged in, only the analog clock inside.
Prior to this, I replaced some simple things like brakes, pads, tires, and filters. When I was driving it from Tennessee to Virginia, the radiator burst. We replaced that and all hoses and all was good again. Drove it 600+ miles and then... I replaced the speed sensor (speedometer/odometer stopped working) and the ignition switch and lock cylinder -- switch wasn't always catching, and the key could be removed from the cylinder while it was running. Now, I've got an ignition problem -- and also the temp is running very high, very quickly. I have a new thermometer, but don't want to change that until I can get it started consistently.
I'm not sure what else I should describe, I'm new at this, so hoping for some help in troubleshooting or the likes.
Thanks!
Thanks!
