AC Radiator Pipe Connection
sherqa
Toyota Land Cruiser GXR Model 2001, 6 Cyl.
I got an accident and the ac pipes at the front damaged, the garage people connected it and told they don't have experience in AC works but connected the pipes.
There pipe comes out from the AC Condenser (Radiator)is diverted in to Two Lines:
1st goes directly to the evaporator
2nd goes through a shut off value
The 1st Direct pipe is connected to the Rear evaporator.
The 2nd pipe which is going through shut off value is connected to the front evaporator.
Kindly confirm if it is correct or not, because I have doubt that the 1st one without the shut off value to be connected to the Front evaporator.
