Air pressure release valve
Ducktape
Hi Guys,
I want to install a pressure release valve in the airline of my build-in compressor. Any one know where I can source something like this to install in the 8mm high pressure gas hose?
You could T into it and install a valve. Just curious as someone who has a full on board air system - why would you want to do this?
I have one fitted to the air tank. If you didn't have a tank, why would you have a valve? Just fit a pressure sensor and link it to the relay powering the pump so that it shuts off the pump.
VIAIR stock all the bits.
"machine mart sell a 160 psi one for £6" according to this thread muddyfrontera.co.uk/wiki/index.php5?title=On_board_air_-_aircon_compressor
which i plan to follow if/when i make mine
