- Jul 1, 2013
So, I seem to have a wires issue. Came to the 105 this morning to find the battery reporting 12.10v , so put it on the charger for a few hours , went for a drive. But when I got back after a 2 hr drive, no starts after setting off from home, the battery was only at 12.15v.
Spent a bit of time and I seem to have this going on:
Starter battery is 'low'. It turns the engine, starts up ok. I read 12.66v across the terminals. After about 5 min, it jumps to the 14.4v expected.
But the moment I put some load on with the engine running, eg. Headlights or heater/blower, the voltage across the terminals drops back down to 12.5/12.6v.
If I drive around without any electronic load, lights off, heater blower off etc. The voltage does stay up, and the battery is happily charging. Given time of year, and weather conditions - I don't want to drive without lights or heating. So, what's up? Alternator on the way out?
Battery is from battery megastore, 750cca, starter, 2 years old, and the health indicator is 'green'.
