Anti squeal shims (for brakes) are they really necessary?
Brett
As the title says, I've just bought a set of remanufactured calipers & I'm going to fit new rotors & pads at the same time.
What's the general opinion on the anti squeal shims? should I buy a set? I've got a feeling I binned them last time I changed the pads :roll:
Looking on ToyoDiy, you can buy the shims individually for £36.72 or as a axle set for £77.55 :shock: either way it's a lot of money for 8 bits of tin.
Re: Anti squeal shims (for brakes) are they really necessary
Hi Brett
Axle set at https://safe.brakeparts.co.uk/loadnew.html are £7.33
So I think Toyota have got there decimal point in the wrong place !
Hi Steve,
That's where I get my brake parts anyway, Brake International. That's the fitting kit you've linked to, not the anti squeal shims.
The fitting kit they do is for the early trucks only I need the longer (115mm) pins.
They also don't stock the anti squeal shims, looks like it's dealer only for the fitting kits & anti squeal shims.
Thanks anyway.
Have you tried Ian Rubie for the shims?
No i haven't, I was hoping to get an answer on whether they are necessary before ordering any.
i dont have them on mine all i got is the pins and springs
I have been told that copperslip between piston and pad will stop squeeling.
Frank
Brett said:
Hi Steve,
Thanks anyway.
Hi again
I have not used Brake international, but I believe a lot do, but do the pads not have a coating on the back of the
metal backing.
But what are those kits I linked to then ? I thought that what the were !
The other point you say the pins are not long enough, get the kit and just use your own pins !
Dont use shimms on mine and I dont have squeaky brakes, cant say the same thing about the volvo though...
My shims fell to bits 7 years ago. Never had any since and had no squeals either.
Thanks for all the replies, I did the job today & I had chucked the shims previously.
All back together & it's not squealing :thumbup:
