Yes, it has been a niggling issue from the start. I am now wondering if low speed cruise control would be useful. If you set the speed output correction to a low number e.g. 5% you can use cruise at very low speeds although the dash speedo will read incorrectly. It's slightly fiddly to change the correction figure so I might add another button that toggles between 2 values for normal and slow speed to make it easier. I will have to try it manually first to see how the cruiser control behaves, the correction rates it uses might be too aggressive for low speed control.The resolution issue is why Oiley hunts & lags in cruise control then... Might have to get that update sorted soon
Awesome work, is TPMS currently possible with it?
What oil pressure sender should I use, or what resistance value range is your system designed for?
What boost pressure sensor should I get?
It appears this system will work with any k-type thermocouple, is that true?
I tried to PM you with some questions about pricing and shipping, but for some reason it wouldn't let me.
I'll be building one for the ML as soon as I have time. I don't think there's a UK importer of the screens now so they have to be bought direct from the manufacturer in the US http://www.liquidware.com/shop/show/TSL/TouchShield+Slide . The Arduino board is still the Mega 256 e.g. http://www.coolcomponents.co.uk/arduino-mega-2560-r3.html . I have to get some more interface PCB's manufactured next week (takes about 2 weeks) I don't use the project boards or home made PCB's any more, too much trouble.Jon I know you have now sold the car and I guess the project may have died or maybe you are about to start another one but seen you started this back in 2011 and we are nearly on the eve of 2015 would you still use the same touchslide and audrino as the links (they no longer work) or would you go with some thing else.
I am looking to get started on this and dont want to buy something that is out of date now.
