ATF overheating in the Alps - Help
Interesting Clive, I'm not convinced either that it needs doing. I've never had any issues with cooling, despite not being able to keep any coolant in my expansion tank but always the same level in the rad.
Is there nothing in the expansion bottle Rich?
It may be that the balance point on your truck is very low. Mine surprises me being on or near to the line, some I've seen consistently over the line on other vehicles but not escaping the expansion tank.
Never anything more than a drop when I look Clive, however there's plenty of rusty looking stuff on the side of the bottle up to about 2/3 full.
Id keep a close eye on the rad level then sc..
I have done CG but it never moves. I will revisit it though as it seems wrong. I have recently changed to Toyota red coolant. Is it best to top up only with that or could I top up with water?
If I check the coolant on my truck when its cold the expansion tank is always empty, but if I take the rad cap off its full to the brim. Even when I top up the expansion tank, the next day when I check again its empty. Having said that, to date I've not had any overheating issues with the engine.
Hmmm, not just me then. Thanks Charlie, I don't feel like the odd one out any more. :text-woo:
I had the same when driving switchbacks. I also have the extreme valve body but temps still exceeded 120C on even a pretty short set of switchbacks (I have a transmission temp gauge so can see the temps). Only way I could mange it on the trip was by using low range. Unless the gearbox can get into lockup the temps rise very quickly. Switching off OD will enable the box to lockup in third I think but doesn't help with the slower stuff.
From what I've read, if your temps have hit the 150C needed to trigger the ATF light (it turns off at 120C) and you're not running fully synthetic, you will need to change the fluid. Wholesale autos recommend Castrol Transmax Z but make sure you're sitting down when you see the price. A full flush and fluid change on mine just used 20 litres!
Do your temps come down quickly once the gearbox locks up? Checking the fan is engaging properly is probably a good idea but I reckon these boxes do get hot pretty easily.
Next up for me is large auxiliary ATF cooler and lockup switch.
Hi, I'm currently playing in the Pyrenees and finding that the ATF quickly gets to 120, and makes me slow down. This is my first auto 4x4 and it appears only to lock up in overdrive/4th. Is this right? I like the idea of a lock up switch. Is there a thread for this, or can anyone tell me how to do it please?
I think it will lockup in 3rd too if you turn overdrive off. The lockup switch I have is from wholesale autos in Oz http://automatictransmission.com.au
There is also a thread on ih8mud detailing how to DIY a lockup.
If you top the expansion tank up does it slowly lose it again? It might be nothing but mine used to do the same with a aftermarket rad (spit) that used to be fitted. I thought it fine until an embarrassing over heating moment on the m6 with a caravan on..
With a new rad on the header tank level hasnt moved at all over the last couple of years.
Thanks, the lock up works perfectly in overdrive but not in any other gear. Does anyone know if it should? Lorin, I assume you are happy with the lock up switch. My gearbox is getting on for 250000 miles so has earned a rebuild. I was contemplating the Nomad valve kit which I also assume will work well with the lock up switch. Do you know if these are available from a UK supplier, and does anybody have any recommendations for someone to do the rebuild and fit these upgrades?
My lockup switch is due to be fitted in a few weeks, so I can report back after. Unfortunately I won't be able to test it on any switchbacks/steep climbs for a while. You could try Julian at Overland Cruisers, he may be able to supply Wholesale Autos kit. Otherwise, it may be a case of ordering from Oz direct.
In my experience of driving auto 4x4s in alpine areas the auto should be driven like a manual, making use of the '3-2-L or 2-L' gear stick position options. By design, and our preference, the autos in our simple vehicles can't tell that its climbing a steep mountain pass so it will keep changing gears as normal, whereas modern vehicles with tons of sensors that all talk to each other would probably be analysing the outside temp and altitude amongst other data to inform the auto gearbox that it needs to adapt its shift pattern accordingly. So in our simpler vehicles we need to do that for the auto gearbox, to protect it and help it get to the top without overheating the ATF.
By selecting one of the '3-2-L' positions you are limiting the gearbox to that gear as its highest gear, then it will hold that gear and you can use the engine revs more, without the risk of the box changing up (it will only override this if you push the gearbox too hard and risk damage). This is a really useful option as a large amount of heat is generated when an auto changes gear.
Putting things into context, a 4x4 is a heavy vehicle which tends to be even heavier when loaded for a trip, we tend to prefer holidaying when the weather is nice so theres a good chance that the ambient temperature is high, mountains tend to be high and steep with loads of switchbacks to allow a vehicle to scale it, and the higher you go the thinner the air gets. So you end up with a heavily laden vehicle scaling switchback after switchback at slow speed, with high ambient temperatures and thin air. The thin air will make the turbo charged diesel engines that often power 4x4s become less efficient and therefore work harder, couple this with the slow speed and therefore reduced airflow over the cooling radiators and its easy to see how this situation can exploit any weakness in vehicle, or push a perfectly functional vehicle outside of its safe operating parameters.
In my experience its easy to overheat an auto in these conditions if it is just left in D and has to work out when to change gear for itself. As the 4x4 is slowly ascending the short stretches between the switchbacks that auto spends a longtime waiting for the engine and road speeds to be appropriate to select the next gear up, then it will change up and start the whole process again to select the next gear. This process generates a lot of heat for every gear change, this heat has to be dissipated by the auto gearbox cooler, be it in the engine radiator or a separate cooler. If it is in the engine radiator then bear in mind that the engine so also working hard and is trying shed a load of heat through its coolant at the same time, which could have an impact on the auto coolers ability to exchange the heat with the coolant. UK market diesel 80's have the auto cooler built into the bottom of the engine rad, but in my experience it is well up to the task of cooling the auto gearbox if the temperatures are managed.
So with the gear changes generating the heat as the 4x4 ascends the mountain, the key is to try and keep them to a minimum and avoid unnecessary changes. I drive my auto like a manual in these conditions and only shift gear if its beneficial, if the length between the switch back is just so that really the 4x4 could pull 3rd but it would only be for a short distance until the next switchback, then I tend to leave it in 2nd and use the engine revs a bit more, or just manage my speed accordingly and not try to race up the mountain, after all the key is vehicle preservation when you are far from home.
Coming into a switchback I would shift down to the appropriate gear for the exit of the switchback onto the next climb, as if you leave the gearstick in 3rd or 2nd the 4x4 will try and hold this gear and then change down once it decides it can't pull the load up the gradient in the current gear, this also generates a lot of heat in the auto gearbox. So by reading the road and shifting the gears accordingly you can be in the right gear to get back on the power as you exit the switchback and make best use of the engines revs and the 4x4s momentum. If the switchback isn't too sharp it may be possible to hold 2nd and keep some of the vehicles momentum as you corner and power out, this obviously avoids generating additional heat by working through 1st and back into 2nd if it wasn't necessary.
By manually selecting the gears in this way you can keep on top of the heat generated inside the auto box within levels that aren't damaging to the ATF or auto gearbox and can be managed by the auto gearbox cooler. Employing this method has allowed me to ascend many alpine routes without the need to stop and allow the gearbox to cool as the overheat warning light has illuminated. That being said it is a very fine line and is specific to the vehicles condition, load and modifications, all of which have a bearing on the auto gearboxes ability to generate and dissipate heat.
Obviously any Overdrives want to be in the OFF position when ascending mountains, and if your auto has a 'sports mode' or ECT (electronic control transmission) as seen on post 1992 80's, this can be used to hold the gears longer if you decide you need a break from manually selecting the gears or want to leave the gearstick in 2nd or 3rd and allow the auto to do the shifting up to those gears.
Measures can be taken to assist with the preservation of the auto gearbox, as have been suggested in this thread, such as an ATF temperature gauge/additional ATF cooler/manual lock up devices. I haven't gone down this route (yet), instead I have chosen to make sure that my cooling system and auto gearbox cooling systems are tip top and then put my faith in them as the designers did an awful lot of hot weather testing on these systems and deemed them capable. Sometimes aftermarket kit can give trouble if they are poorly thought out or installed, after all the OEM set up has lasted 20+ years on many of the 4x4s that people use for overlanding, yet you find that an aftermarket cooler or gauge starts give trouble due to a poor connection or rubbed through hose after just a couple of years. So first make sure the OEM set up is tip top, then choose aftermarket modifications carefully and make sure that they are correctly installed and fit for the environment that the 4x4 is going to operate in, as what may last years running around in the UK may fail after just one Morocco trip.
What goes up........must come down! I find ascending easier than descending, as you can easily stop during an ascent to have a breather, but during a decent if you haven't been preserving the brakes it can be very difficult to stop an auto.
As a general rule autos provide less engine braking than a manual, so descending a mountain in a heavily laden auto 4x4 is a game of making the best of the engine braking available by manually shifting the auto gearbox and careful use of the brakes. I have had to stop on a couple of occasions to allow the brakes to cool during a descent as the early on set of brake fade could be detected. I find high boiling point brake fluid and uprated brakes can help. Just leaving the gear stick in D and leaving all the braking to the brakes can result in total brake failure, I have seen it happen, so much smoke was pouring off of all four brake discs that people thought the 4x4 was on fire and came running with fire extinguishers, (no this wasn't my vehicle).
I hope that is some help and if it saves one persons auto gearbox it was worth the effort in typing!
Pumpy - Sorry this has come post your trip but I hope that some of it may help you on the next one. As has been advised elsewhere, I would change your ATF even though it seems ok, as it has seen some action which has probably shortened its useful life expectancy. plus it has already done its job.
Useful post Scott, in my case I was using the box manually, just pushing too hard trying to keep up with the others, using low range and taking it eaiser I had no further issues - just told them it's better to wait a few mins for me at the top than 40 mins for the box to cool down! (I think there are issues with ratios running 35" wheels too)
I had no issues coming down, again in low box, with judicious use of cadence braking. When we stopped at the bottom I felt all the wheels on all the vehicles, mine were the coolest as it happened, couldn't touch the TD5 fronts they were that hot!
Yes, low range is a wonderful attribute to a 4x4 (its a shame not all modern 4x4s have it). A wise move to select low range, this is when have the centre diff lock mod to prevent auto locking of the centre diff when low range is selected comes in really useful. I once helped an 80 that had overheating ATF halfway up a mountain, we ran the engine at fast idle with the auto gearbox in neutral to help cool the ATF, then proceeded the rest of the way up in low range with occasional breaks to aid cooling and admire the view. This allowed the 80 to make it camp that night, it was later diagnosed with a transmission fault by a garage.
It looks like weight, possibly restricted airflow, over gearing due to the larger tyres and chasing faster cars combined to cause the auto gearbox to generate more heat than it could shed. Glad you caught it in time and took measures to protect the vehicle so that you could continue. As you have said in your other thread, re gearing the diffs to bring the 80 back to standard gearing is a wise move in the right direction.
Here is a useful little modification I was told about and haven't heard mentioned on here.
Last year in the Pyroneese I had a few issues with my A/T temp light coming on, nothing serious, just dropped it into low range and it went off. It puts that little niggle in your head for the rest of the trip and then it won't go away!
When I got back I was told that petrol auto 80's come standard with an extra oil cooler rad fitted in front of the engine and A/C rads. I got hold of one with the mounting brackets and filled it to my HDJ 81. All the captive nuts are already their, no cutting, drilling or welding to be done, just bolt it on and plumb it in, simple.
I've just returned from the French Alps where we did the Col De Parpallion tunnel and the Col de la Bonette so over 2800m elevation and never saw my A/T temp light. Result.
Now that is useful to know. Thank you.
As someone has mentioned it this is the auto cooler in mine (petrol), tbh I didn't know it was any different to the diesel.
The gearbox does get quite warm and there's a lot of residual heat from the engine, Trans tunnel gets bloody warm inside even the selector lever.
Never driven In the alps but do sometimes push the 80 hard on 35s, so far haven't had a temp warning.
Thanks for that Gary, looks like it's right where my intercooler is :coldsweat:
Has anyone got an intercooler fitted, and an ATF cooler?
Speak to Julian from Overland Cruisers, he will be able to offer some good advice.
