Lorin
- Mar 28, 2010
I am about to install my third battery and split charge system and want a way to monitor the charge status of each of my 3 batteries (two starters and one leisure). However, a top consideration is cost. I know there are some pretty fancy battery monitors out there (notably for marine applications) but they are also expensive. Also most cannot handle 3 batteries.
I've found these (12v digital voltmeters) http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT and was wondering if there is any reason they wouldn't be sufficient for the job. For example, do I need to be able to measure anything other than volts in order to determine the status of a battery? My plan would be to fit one to each of the batteries with a simple switch so that they are not permanently on.
I plan to carry a digital 12v electrical tester on the basis that if a battery monitor indicated that a battery wasnt charging I could check the alternator etc.
It is my intention that the system I install is both simple and idiot proof! Therefore, I figure I ideally need to be able to see if a battery isn't fully charged or is losing charge etc at all times. I also plan to fit a simple alarm to each each of the batteries that sounds or flashes when they drop below a pre-set charge.
Do people think this would be sufficient in terms of keeping an eye on charge/battery status?
