I am still in the design phase and maybe should have provided more information so that you could give a more informed reply.
To simplify things for this question the plan is to have one starting battery with the sole purpose of starting the engine. Once the starting battery has reached full charge a voltage sensing switch will open it up to the 1[SUP]st[/SUP] aux battery to charge it and once this has reached full charge the same again will happen to the 3[SUP]rd[/SUP] battery which is the 2[SUP]nd[/SUP] aux battery in a removable battery box in the rear.
The plan is to only use the 3[SUP]rd[/SUP] battery for only the fridge on long trips otherwise it will be removed. The 1[SUP]st[/SUP] Aux battery will run all the auxiliary things like, inverter, usb charging points, GPS, Air compressor, cb radio and other bits.
My knowledge of electricity is somewhat limited and so there will be many further questions BUT back to the reason for the switch is so that if need be I want to be able to bypass all the voltage sensing switches and link the starting battery with either the 1[SUP]st[/SUP], 2[SUP]nd[/SUP] or both aux batteries if not to start a flat starter battery if the worst should happen but also to winch and to use it to isolate the starting battery when in camp so there is no chance of a draw on the starter over night or whilst parked up.
The batteries will charge off the alternator and using a ctek ds250s and the option of a solar pannel.
