Blower Motor resistor location
blindsey Aug 10, 2018
  1. blindsey
    blindsey New Member
    1
    0
    1
    Map
    my ac only works on high speed and I’m trying to find the blower motor resistor. Chilton manual says it’s in the cooling unit, but I doesn’t say how to access it. Could anyone tell me how to locate it? Thanks for your help in advance.
  2. Trevor
    Trevor Well-Known Member Supporter I am in england
    1,676
    183
    63
    Map
    Under the dash on the passenger side (UK vehicle) you have the blower motor case, IIRC the motor resistor is a black vertical rectangle with 2 screws just to the left of the motor case, one at the top and the other at the bottom. undo those and then pull it out towards you.
Share This Page
    Dismiss Notice
