Ollie
- Feb 14, 2020
Hi, I know there are loads of posts on spongy brakes and getting no pedal etc etc. I think I've read them all and we still have a problem that hopefully someone can shed some light on.
To set the scene - my 1999 5 door Colorado is in my mate's workshop. He's a very experienced (nearly 40 yrs) mechanic and I trust him to always work out what's wrong with my vehicles from 1960's Land Rovers to much more modern cars . However, this has got him and his colleague stumped.
When I got this Land Cruiser it pretty much went straight into him because the MOT was soon due and the brakes were appalling. The car nearly shook itself to death every time I tried to stop. So news pads and discs were fitted along with new rear callipers.
So now the shaking has gone but he cannot get a decent pedal.
He has gone round and round to try to find the problem. It's had a new master cylinder, and then the old one put back on in case the new was bad. He knows about bleeding the master cylinder, that I have read on here.
When we clamped all four flexi hoses there was a pedal so that would take the MC and the ABS out of the equation.
As soon as we unclamp any one of the hoses the pedal goes nearly to the floor again, although possibly slightly better with only both fronts clamped so maybe that is down to the rears needing to bed in as everything is new?
I've read comments about the flexi hoses de-laminating inside but wouldn't any bulging be visible? We clamped/unclamped one of the rears right at the calliper end and it made no difference. Perhaps we should try all four corners just to be sure.
Apart from the hoses, the only things to replace now are the front callipers and the compensating valve at the rear. If I have to buy all this then I will but he's struggling to believe it's the callipers and if it were the valve would it be evident when the hoses are all clamped?
We have tried to see if there's any more air in the front callipers but taking one off and getting it to an angle to expel anything that's left - but no bubbles present.
He did mention something about the inner (I think) pistons on the front calliper he was looking at not moving and the disc being moved slightly. Does fluid get pushed around to the other side of the calliper which wouldn't happen if there was a blockage?
So, I am ready to buy new front callipers but really I just want to be sure that the compensating valve isn't the issue, as I'd buy that first as it's cheaper!
Help. Me. Pleeease
Ollie
Help. Me. Pleeease
Ollie
