stuzbot
- Jan 20, 2021
I don't want to get ahead of myself here, since I still have to sort out 'The Case of the SumpPlug Made of Cheddar' but, while I was out yesterday, I also thought I'd take a pre-emptive peep at the cambelt, since I have a new belt and tensioner waiting to fit. Just to check the old one wasn't looking like it was about to disintegrate in the meantime. [I haven't got the cambelt warning light on the dash or anything. But, given the hidden surprises I've found so far, I wouldn't put it past the previous owner to have cancelled it, if it did come on].
Anyway, old belt looks OK for another while, but I'm a bit confusticated as to where the timing mark is for the cam shaft. I can see the one on the pulley. But there doesn't seem to be an obvious one on the back-plate:
This, I reckon is lined up pretty much where you'd expect TDC to be....
As confirmed by this, which I'm assuming is the mark for the crankshaft pulley...
Actually, the crankshaft pulley seems to have a whole selection of timing marks. These ones look to have been added later. But thankfully they all agree with each other....
So, where is the timing mark for the top pulley hiding?
