Centre console power outlet
Burger
australia
Any ideas where the fuse is for the centre console cigarette/ power outlet on a 78 series . Which particular one ! Not the CIG
I assume its the same as other cruisers and the lighter socket itself is a fuse , wire on the back of it melts before the fuse blows :confusion-shrug:
I fixed mine with solder wire and put a smaller amp fuse in the box .
Actually on reflection that fuse link inside the socket is overheat protection so a rated accessory such as a tyre inflator will work as it should but not continuously .
