Ian Rubie
Moderator
- Feb 24, 2010
I cannot get TechStream to connect to my 2004 UK spec HDJ100. I know my TechStream installation and cable are working because I can connect to my Lexus with it. I have been able to connect to the 100 in the past with the same software and hardware that I am currently trying with.
I have checked the 7.5A fuse in the passenger foot well and that is fine.
I have tried using a normal code reader that is powered via the socket and that powers up. I was not expecting it to connect because it is not Toyota compatible but the fact it powered up shows there is at least power to my connector.
What else can I test \ check? I've currently left the car with the batteries disconnected just in the very remote off chance some ECU needs a reboot.
Ian
Ian
