you could try interpolating it from the OME data table, probably wouldn't be too far off, or just take a set of springs to a spring makers and have them measured, they'll probably do it for free if you're having them make some to your spec.
Yea maybe I'll have a go at working the info backwards. It only works for the rear springs as they are normally +150, 200, 300Kg (I Guess this is per pair), but the front shocks are +0 to 50Kg or +50 to 110Kg etc. Not going to have any springs made just trying to make a good decision about up rating my current rear spring set up. As all will know I have the Ironman +40mm kit fitted that gave me +50mm once fitted with an empty truck. When loaded with a full tank of fuel she drops more than the 50mm gained from the lift. Last weekend I took everything out of her, now bearing in mind she has no camping gear, food for a weekends trip, two small boys and an empty fuel tank (fuel warning light on) she came up 44mm!!!!
The items that I removed amount to about 150Kg;
Shelving unit, tools, spares and some recovery kit 90Kg (this weight lives in the truck & is never removed).
Off-Road kit coffin box, Hi-Lift, waffles, recover chain, blocks of wood, spade, large axle stand and a few misc other bits 60Kg.
Just these two lots of kit drop the truck nearly all of the gained lift!!
But then add to this;
A full tank of fuel 90ltrs approx 90Kg
Camping gear including tent, sleeping and cooking gear 20Kg
Food & water for 2/3 days camping 15Kg
Two small boys with car seats one 20Kg the other 28Kg
Clothes, boots, DS's, iPods, iPads, iPhones, Chargers bla bla bla perhaps 10Kg
Sorry started to get a bit carried away there
I guess what I'm looking for is to maintain a bit of lift while loaded for a weekend away, so whats that lot total up to then
333Kg
Mmmmm..............not a massive amount compared to others I shouldn't think and I'm not complaining about sagging as Chris was. While doing all of this I've discovered that over two years and some pretty heavy abuse my Ironman springs have only settled by 5mm ish. They're just not giving me the support that I want from my springs, apart from this I'm over the moon with the flex and ride that they give. Maybe spacers are the answer
The reason I'm after the standard spring rates for 80 and 90/95 springs is that I just want to compare the 80 series standard front springs rate to the 90/95 series standard rear springs rate and then compare these figures to the Ironman TOY039B springs that I currently have fitted, but you can't find out this info for any of the mentioned springs.
I'm on the cusp of buying a pair of 80 series springs as Chris has, but also wonder if I should be buying a set of new ones or well used second hand ones.
I'm not sure that anyone can help me with what the correct thing to do with regards to spring type to fit or spacers or air bags, but the spring specification information would be great
edit - Oh, I forgot about the rock sliders! Probably another 40Kg, I'm not sure that the front winch install effects the rear suspension a huge amount!
