- Feb 2, 2013
the engine has felt slightly strangled. Like a blocked air filter almost. No, the air filter isn't blocked.
Try as in test , alternatively you could spend 30 quid on a high flow filter just to try it .
Beau, that may well be pure genius. Unfortunately, I can't say if it is or not. This is the first time I have ever dealt with an EGR and all I know is it's valve of sorts that lets exhaust product back into the airstream to be burned. There is some arrangement that means that they don't open all of the time so they are connected to the ECU in some sense.
Now, I am not trying to block the EGRs are such - not yet, I am just stopping them activating to see if it cures the black soot, which it does. But as I have said, something else is happening too. Blanking them fully would be the right answer. I know that. But I wouldn't want to do that if the net result was the same as I have now. I'd rather have the soot!
I don't know what pushes the gases through the EGR. Back pressure? Could it be that the pressure is pushing back into the cylinder somehow, strangling performance? I really have no clue as to what's actually happening.
Thing is that the EGRs are not open all the time. So when they aren't, they are in exactly the same position that they are when they are blocked. I don't know if there is some form of feedback to the ECU that says "When the valve opens, alter X setting". With me simply blocking the pipe, the valve is supposed to be open but isn't.
But people have removed them without problems and in fact have seen benefits. That's what I don't get. What do you do with all the solenoids and wiring etc?
Interesting observation.My 24v could do with one by the sounds of it. It stops with a right bang and judder. The 12v just sops. All my 12v 80's have just stopped. But the GS is different. I'll see if it changes with the removal of the EGRs.
My 24v could do with one by the sounds of it. It stops with a right bang and judder. The 12v just stops. All my 12v 80's have just stopped. But the GS is different. I'll see if it changes with the removal of the EGRs.
