- Feb 2, 2013
Factory set fuel delivery only enough to match 5psi of air would run so lean it would stop the engine if you were actually ramming 10psi into the mix . A bigger injector delivering more fuel than the ecu is aware of could bring the fuel air ratio back into spec .
Double numbers is a bit extreme but it helps to get the principal across .
