Beau
- Jan 28, 2011
Ok guys, really need your help here!
About 2/3 month ago whilst driving my cruiser (Colorado) just cut off on me and a bit of smoke came through into the cabin from behind the head unit area and drivers side foot well. I pulled over and checked everything, no broken or burnt wires, everything fine in the engine bay - Puzzled! The car didn't stutter, it just shut off. Anyway, after removing the headunit and trims ect and finding no blown wires, fuses ect I started her back up which happened instantly and drove home fine.... Not a problem...
Couple days later I could smell the smoke come back (Smelt like burnt wires) but thought it could just be a residual smell. So anyway for a good couple months now the trucks been fine, not a problem until now.
Driving home and the engine limp mode light comes on, but no lack off power so thought it was a electrical problem. So when I got home popped the bonnet and checked all wires! BINGO! Found a broken wire for one of the plugs going into the fuel pump, disconnected the batteries, soldered the wires back together, checked everything else, plugged it back in and turned the Key.
Started for about 3 seconds and then dies, no judder, it just shuts down like the immobiliser kicked in. Now this is where things take a turn for the worse. Tried starting again and again, same thing happens. Now all various lights flashing on Dash, Alarm light is flashing and making a really loud clicking noise. No electronics work in the car. Can't use the windows, switches, radio, nothing! Only thing that lights up is the dash and most of the warning signs are illuminated. Checked back all wires, nothing wrong. Unplugged the brown connector which had the broken wire and same thing, starts but shuts down - Reckon the broken wire is unrelated...
Whilst messing about trying to figure out I can now small that burning wire smell coming from somewhere behind the dash. Messing around with all the switches I find if I put my headlights on the starter motor doesn't engage and the alarm clicking sound stops. Have disconnected batteries for 10 minutes in hope for it to reset something but nothing. I have removed the head unit and surrounding pannels but no wires are visibly burnt or broken, will have to go deeper in I guess
My thoughts were initially the immobiliser but after smelling that wire burning smell I have second thoughts. I reckon a wires fused/burnt/bridged ect and has caused the trucks electrical system to go mental! Getting Dark and staring to rain so have called it a day outside. My plans are to remove most of the fuses which aren't needed to start the car and see if it starts and runs, if it does then I'll slowly plug back in fuses one by one until I isolate the problem. If this fails I'll have to remove the entire dash which is a nightmare if anyone has done so before. Everything needs to come out! I've done so one before when replacing the Heater Matrix but it was a Pig of a Job!
Anyway if anyone can shed some light on what else could possibly be the problem or help, that'll be great!
