faultcode p0778
peter kohler
netherlands
HI all.
I have a Landcruiser 120 3.0 d4d with a automatic tranny in the workshop
I't won't shift up to Fifth and has a fault code p0778
p0778 : Pressure Control Solenoid "B" Electrical (Shift Solenoid Valve SL2)
so I droped the tranny pan en removed the solenoide, electrical resistance is OK ( 5.5 ohm )
clicks ok when 12v is applyed, so i'm sure the solenoide is OK, checked the wiring inside the tranny, also OK.
does anybody have a electrical schematic ? so I can check the wire's to the transmission computer ?
hope you all can help me with this problem
