Matthew1955
- Aug 20, 2017
Having been searching on line I have found an LC4 I like but it has a bit of a chequered MOT history with a few problem,could any of you good people out thee advise me on if I should be particulary concerned and what the replacment/repair cost might be,the car is a 2005 with 85K on the clock,it has a FSH.
2011 at 56K Pass with advisory
Offside Front Upper Suspension arm has excessive play in a ball joint,Passed the next day
Advisory ATF Fluid leak
2013 at 72K Pass
Advisory
2015 at 83600 Pass with Advisory
Nearside Front Upper Suspension arm ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.4.G.2)
Passed the next day
So the car has had a number of issues most of which have been corrected but has had and still has the ATF Fluid leak and I am not to sure about the four slightly corroded brake pipes.
I look forward to hearing members thoughts,
Thanks Matthew
- Rear Brake pad(s) wearing thin (3.5.1g)
- Nearside Front Brake pipe slightly corroded (3.6.B.2c)
- Offside Front Brake pipe slightly corroded (3.6.B.2c)
- Oil leak
2013 at 72K Pass
Advisory
- Nearside Rear Brake pipe slightly corroded (3.6.B.2c)
- Offside Rear Brake pipe slightly corroded (3.6.B.2c)
- Front Exhaust has a minor leak of exhaust gases (7.1.2)
Passed the next day
Thanks Matthew
