ive got a fuel starvation problem on the main tank only,sub tank ok,I filled up with fuel added 150 mls of repco diesel injector cleaner only to the main tank , sub was already full, drove 300ks stopped for half an hr then started the return trip that's when it started to die like it was running out of fuel I changed to the sub tank it ran normal so I filled the main with fresh fuel and set off back down the highway . I got back by running on the sub tank for 15mins then change to the main it would run ok but down a bit on power til I hit a hill then it would play up again so I would change to sub tank for 15mins again and so on til I completed the 300 ks. any ideas what the problem could be before I pull it apart. has any one had this problem . thanks Dave
