bandsnbrakes
- Mar 17, 2014
Is that rust? Looks like water has got in. Rust is very abrasive and would wear through splines unless the gearwheel is pressed on which I don't think they are. Transfer oil should be changed every 36k miles.
Couldn't agree with you more about the rust abrasion Frank, I think that there is also varnishing/oxidation issues in there judging by the brown on the gears. Oxidation of oil is not good it fast loses its scuffing and EP properties etc. I have had a transfer chew its gears up after somebody ran it with hardly any oil. The transfer is very strong, but still needs to be maintained.
