ok so how much grease is ok to have on the abs rings?
I have been having an intermittent problem with my brakes/ABS it feels as if when the truck is about to stop the abs activates and lets go the lefthand front brake and the truck pulls sharply to the right but its only at the very last second before it stops. I knew my inner axle seal had gone on that side so when I took it apart the swivel was full of axle oil and cv grease and the abs ring was plastered. I also notices small metal filings on the abs sensor and it appears that it may have been in contact with the abs ring. I'm not even sure if the two are problems are related.
has anyone any opinion on the amount of grease if any is acceptable to have on the abs ring.
has anyone had problems with milners hdk CV's being out of tolerance and catching the abs ring. I rebuilt the whole axle including the stub axle so assuming the new bearing is keeping it all central...
