Howmanygoes
- Jan 14, 2019
Oh FFS I sodding ordered H4 instead of HB4, bloody drop down selection rushing.
anyone want them before I ship them back.
Can't see the thick white coloured paper.Don't put bulbs with different shapes and sizes than the stock ones in the original reflectors! The glare will be unavoidable.
There are two ways to improve things.
Upgrade the bulbs from the halogen 9005/9006 to HIR 9011/9012. Same physical shape and size, increased light output and life. Requires a minor trim (literally 2mm) on the bulb.
Second is to properly retrofit projectors and then adjust the beam pattern.
I did the first and there was a definite improvement which I was happy with for several months. Eventually I filled the headlights with mud and had to open them anyway, so...
Toyota has a very specific instructions on how to aim the headlights on the 100
It's an irreversible modification - you have to do some grinding on the headlight housing. But then you will never want to go back.
I used Morimoto Mini 2.5 projectors, which are fairly popular projectors to retrofit.
i fitted led before i changed my light and found the four sided best as its similar to original and it passed mot ok .sometimes the 2 sided cause reflectionsCan't see the thick white coloured paper.
I disagree there are some good ones out there that are ok I got not tester to test them until we got correct type sadly I can’t remember which ones they wereI have a set of 5 Wagner 9011 bulbs for sale if anyone is interested
I had to make do with the striped garage door, masking tape and careful measurementsCan't see the thick white coloured paper.
That’s as good as any way , it’s amazing how accurate you can beI had to make do with the striped garage door, masking tape and careful measurements
The cut off and brightness are amazing and I highly recommend that, over any sorts of upgraded bulbs in the stock reflectors.
A good tip that, successfully done it many times with different vehicles, after an old boy near my lock up came over to see what I was trying to do at random in the dark, and put me right.I had to make do with the striped garage door, masking tape and careful measurements
I like a good tip.A good tip that, successfully done it many times with different vehicles, after an old boy near my lock up came over to see what I was trying to do at random in the dark, and put me right.
To late, I've put a bet on, 3:30 20 to 1 on Tractionman, with a handicap of gob as the jocky. Don't think it's a winner.Yeah, I've got one for the 3.30, dead cert 20 to 1 odds, but I'm not telling you !
How much money did you have on ?To late, I've put a bet on, 3:30 20 to 1 on Tractionman, with a handicap of gob as the jocky. Don't think it's a winner.
Life is short. Stop worrying. ...
Just my usual 'Tuppenceworth' as I think the Nag needs a Headlight upgrade. I ment bob.How much money did you have on ?
Not too much to lose then, the jockey threw the race !Just my usual 'Tuppenceworth' as I think the Nag needs a Headlight upgrade. I ment bob.
