Interesting!
Just checked the electrics and it seems to be classed as extra?
See attached file from the manual under diagnostics, clearly shows as seat only 'standard'
Makes me wonder if they just fit them and dont plug them in if you dont want them!
also attached location diagram if any use?
Looks like i will be testing mine this weekend!
Feel like i am missing out on something,
Would be nice to know when and what models is was introduced on or maybe all models after a certain date?
Both the LCs i had never had rear back heaters
Simon
So after checking under the passenger seat i notice a lead going into the back of the seat,
Separated the connector and checked supply was OK, then checked the resistance across the back heater, about 8 ohms, plugged it back in and it was working!!!!
I seems that the passenger one has always been working, its just that i have never sat in the passenger seat with the heater on!
Checked the drivers side and there is an open circuit on the heater so i guess its bust
I know you can buy the heater pads but i dread to think how it can be changed as i cannot see any access to the pad?
Sorry about the pic sideways, its the correct way on my PC?
Simon thanks for the update and the information. I'll check mine - I suspect I'll be in the same position, so thats at least two of us who want to know how to change it!
