- Feb 2, 2013
Hi all i've just got around to replacing my headlight/wiper/indicator stalks coz theres a short inside that sometimes turns my headlights off when i indicate left or right . Battery has been disconnected to keep airbag safe , unscrewed the lower panel , took the screw out of columb panels or box , popped a little entry panel on the side of the wheel hub to reveal a screw . And then coz i hate breaking the little plastic clips i decided to have a look at my Haynes manual to be sure i'm not removing more than i need to .
That's when i discovered Toyota have borrowed it while my truck was in for very expensive repairs and a full service !
I'm thinking the screw i found under the inspection panel on the underside of the wheel itself holds the horn cover in place so if i remove that i should be free and clear to continue .
Or is it a self destruct button ?
