Hi all,
My windscreen washer no longer works. When I pull the stalk the wipers come on but no washer fluid comes out.
I've poked a bit of wire down the hole and the reservoir is full.
I've just add another look today and I can't hear the pump. Fuse is fine as it does both wipers and washer has far as I can tell, and the wipers work.
The rear and head light washers work fine and I can clearly hear the pump working when I operate these.
Are there 3 separate pumps or do they work of the same one?
Any advice gratefully received.
Thanks
Thanks
