Jon Wildsmith said:is that an ABS sensor wire it's cut through?
There shouldn't be anything electricaly special about the wire (I've repaired a few ABS wires now), it just usually has a thick sheath for mechanical protection. Try and put heat shrink over the joints and then wrap it all in self amalgamating tape to really seal it up and avoid small current leakages at a later date would be my advice.24Seven said:Yes, I'm hoping I can rewire that or I'm guessing I will need a new wheel sensor as well.
Jon Wildsmith said:That is lucky - lucky it didn't do any major damage and lucky your trip wasn't spoilt by it
Jon Wildsmith said:It might be that the top bush's were too stiff or that the nut was done up too tight which puts a lot of extra stress on the pin.
