HZJ75 Troopie Body Repair Pannels -
SS427
Hi all, in the process of looking for an HZJ75 Troopie. I’m in England.
I’ve found one, but it needs
1/ Welding to the base of the screen surround
2/ The rear corner lower rear 1/4s are bad
3/ The lower rear 1/4s in front of the rear wheels
4/ Front floor pan corners.
Possibly other body repairs.
It is also going to need a pair of rear springs, rear shocks, plus the rear brake back plates are corroded ( these may shot blast and powder coat up ok )
Any recommendations for body panels and repair sections ?
I sourced all those for my 60 from Cruiserworld. Mostly before brexit and import duty!
It may be worth going over to collect them if you have a big list.
You could also try the Landcruiser Restoration Company in Belgium www.lrc.eu They have a big stock of old parts, mostly 40 series but may have 70 series too
I had the rear corners and B pillar areas repaired on my 70, (similar and same rot issues) The fabricator just cut out the rot and welded in repair metal to be as good as new. Not sure where you’d find new panels in the UK without buying from Toyota. May be worth a dig around German groups?
