Decided to look inside the radiator remote expansion bottle through shear boredom. OMG WTF white sludge on the surface. On removing a sample and rubbing it in my fingers it became apparent that it was what I had dreaded=oil. After mounting panic and checking the oil dip stick I suddenly realised the problem. I had flushed the cooling system in the summer and replaced with new fluid. I had gone for a run to settle things in then in the morning had topped up the cold bottle with power steering pump oil by mistake. Both red and in spare bottles under the bonnet. I had syphoned the useable antifreeze out to reuse but this must have had some oil dissolved. Going to bed to recover now.
I wish I could have found the video clip from the film but here goes ...
- Its most famous sequence was the pre-joust toast (between Hawkins and Sir Griswold), before which Griselda warns Hawkins about the location of poison in the toast vessel, with the famous tongue-twisting "Vessel with the Pestle" dialogue ("The pellet with the poison's in the flagon with the dragon; the vessel with the pestle has the brew that is true.") At first, "the pellet with the poison's in the vessel with the pestle; the chalice from the palace has the brew that is true!", but then one of the containers breaks, so now the flagon with the dragon has the pellet with the poison.
Hubert Hawkins: I've got it! I've got it! The pellet with the poison's in the vessel with the pestle; the chalice from the palace has the brew that is true! Right?
Griselda: Right. But there's been a change: they broke the chalice from the palace!
Hubert Hawkins: They broke the chalice from the palace?
Griselda: And replaced it with a flagon.
Hubert Hawkins: A flagon...?
Griselda: With the figure of a dragon.
Hubert Hawkins: Flagon with a dragon.
Griselda: Right.
Hubert Hawkins: But did you put the pellet with the poison in the vessel with the pestle?
Griselda: No! The pellet with the poison's in the flagon with the dragon! The vessel with the pestle has the brew that is true!
Hubert Hawkins: The pellet with the poison's in the flagon with the dragon; the vessel with the pestle has the brew that is true.
Griselda: Just remember that
(Oh and unmarked bottles are bad)
