Right so a tenner for one of them then .
Go for it Shayne, it'll either work or it won't, no big deal
What do you think of that Sirius antenna Clive ?
The vulnerable bit is the swivel bit allowing the aerial to be angled, I slid a tube of metal pipe over the angle bit for re-enforcement until I got a proper solid one from Jon W.You mean this one Shayne?
The base looks a bit vulnerable, considering it's going on the top of my front winch-bumper, but otherwise looks good, but I can't find dimensions of the mount base, probably not looking closely enough...
That's the one i was looking at Clive because its a case of drill a hole and bolt it on . Try as i might i can't find any that strike me as being strong so for me the Siruis leaves the weak bit protected between bumper and window and the rest will take damage like a coat hanger might so fit and forget me thinks .
Obviously i don't know how that would work for you but i was thinking maybe you could put the delicate bit inside your bumper and just have the whip above .
Mind you ideas are all well and good but some feedback on whether it would work or not from those with experience would be appreciated .
That's useful Chas.
I presume the antenna detaches low down on the angled "ball" type fitting.
If it does, then when in use I take my chances, but when detached, I think the mount will be safe enough.
The choice seems to be 1ft tall like the one i broke or 3ft and over .
To be fair it was the magnetic mount that broke so the same fitted to a body mount on Clive's bumper might be good i guess ?
I can't see the same working for me because of where i want to mount it , fair enough i can imagine the radio and antenna chatting through the window but but any outside signal would just bounce clean over my truck would it not ?
I never realised it was this complicated, I just stuck it all together and turned it on
http://www.ebay.co.uk/itm/Sirio-Ome...053?pt=LH_DefaultDomain_3&hash=item53ee9b1385
I think the sensible thing to do us just copy Chas Clive don't you .
