warrenpfo
- Jul 21, 2010
Now that I have the 16” alloys for the “new” tyres not only am I going to give them a refurb and a lick of paint myself as well as practicing changing tyres prior to painting I also want to install a second valve so that I can run a tyre monitoring system.
Does anyone know the process, risks of self drilling a hole to that the 2[SUP]nd[/SUP] valve would be on the opposite side of the current valve but on the inside of the alloy behind one of the spokes so its out of sight and out of mind.
The reason for this is 3 fold. The first being if it can’t be seen then hopefully the thieving buggers in SA won’t know the sensors are there to be stolen. Secondly I want to run the sensors that screw onto the valve body rather than installed on the inside of the tyre and thirdly I figured it may help to balance the tyre if its opposite the current valve and being behind a spoke it wont be prone to rocks or getting ripped off.
I had thought of using these valves.
I don’t want to damage the rim or weaken it.
