Paul said:What antenna are you using with the laptop?
Paul said:Cool, the one i have only works in my living room.
Are there any issues with connecting/disconnecting? Although i suppose there is no need really as its small.
What sort of spec is your laptop Toby? I am considering a EeePC from maplins @ ~£170 for the zigact same purpose - 8.9" screen, WTF, here's the link!!! EeePC 901TobyJug said:The Memory map laptop is on xp.... I pretty much only use that one for memory map as it was a cheap one..
Gavlad said:What sort of spec is your laptop Toby? I am considering a EeePC from maplins @ ~£170 for the zigact same purpose - 8.9" screen, WTF, here's the link!!! EeePC 901TobyJug said:The Memory map laptop is on xp.... I pretty much only use that one for memory map as it was a cheap one..
Thoughts?
Rob said:Gav that hard disk is rather small for memory maps, 12.9GB for the whole of the UK, but you could not load all of them at once. Also I think that that is a pic of the 10" screen model.
Rob said:white PCs look like macs
