I'm on the slippery slope. OK, the customisation of the new Cruiser has started, the thin end of the wedge? , today I had a Clifford Concept 650 alarm fitted, it's the dogs doodahs , I could never have fitted it myself, it took the fitter 4 hrs to dismantle the dash and the doors inside and connect up all the necessary wires. it does all sorts of magical things, sets itself if you forget, tells you if someone has tried to access the car while you were away, if you lose the remote that one can be deactivated and then you use the spare, and it chirrups at you if you just stand too close to look through the window
